Return to Index
Read Responses
Eddie, I have done the exact same thing and ...
In Response To:
This may be late, but
have gained a lot of peace of mind from it.
Question on exhaust gas temperature
You could always test it...
Check with the operational instructions
I have neve actually measured...
Too many variables/
If the engine pumpe plenty seawater into the exhaust, then
The btu's exchanged with the raw water and the change in the temperature and flow varies
We have an flow alarm on the engine raw water supply
Seems like a good idea. Can you give me specs or
I have a 15 year-old Aqualarm panel
From the thermodynamics and relative water and exhaust volumes
I think what you said..
That seems about right
