Return to Index
Read Responses
Thanks
In Response To:
Yes, if you want to get the best finish match
Thank you Larry, that confirms it. I'll use a poly and thicken it a bit.
W
Gel coat
PS -- if you're friends with your dentist
Thanks
If you have enough gel coat
Better check that can of factory gel coat
Also check color
Everything went bad in a year.
