Also check color
It's very likely the color of the boat isn't the same as it was when it came out of the factory, even after compounding, because of UV and weathering.
A good way to match color is to apply some gelcoat (without hardener) to a clean area, and blend as needed to see how close you can get. Once satisfied, add the hardener.
