Return to Index
Read Responses
If you have enough gel coat
In Response To:
Yes, if you want to get the best finish match
You can thicken it with a bit of cabosil and use it to fill the holes.
Gel coat
PS -- if you're friends with your dentist
Thanks
Better check that can of factory gel coat
Also check color
Everything went bad in a year.
