You need to call the distributor -- like Mack Boring.
In Response To: Yanmar exhaust system diameter ()
Yanmars have a very robust and protective cooling system. That's a good thing. The difference in cross section is 225% between 3" and 2".
I think the intake is smaller than 3". The discharge is larger and 3" sounds right.
Get the bronze riser, it will generally not get gunked-up.
