Return to Index
Read Responses
Loved my Garhauer rigid van.
In Response To:
Loose the topping lift. It's a PITA under
Stackpack
Sail not dropping fast enough? My stackpack would stuff itself unless I lowered slowly
stackpack
Have you checked out the Dutchman sail flaking system?
No topping lift
Consider lazy jacks....
Lazy Jacks
Lazy jacks
Maybe a little repositioning would help...
Setting up the lazy jacks
Why can't you rig one?
Topping lift
Backstay? You mean the roach is beyond the line between the masthead and the boom end?
My Freedom 25 had lazyjacks, worked perfectly.
Photo of system on 265' main with full battens.
I rigged a topping lift with a large roach main
I have a "Lazy Cradle" from UK sails that
Had both a Macpack & Stackpack
I have Stackpacks on both main and mizzen....
Lazy jacks can be made to...
I'm not sure that would work with a Stackpack type cover...
