I guess it depends on what sort of projects you take on...
I don't know how I could do the sort of projects I do on my boats without...
Table saw, band saw, surface plane, two electric drills and an electric impact driver, several hand planes, set of chisels, a couple of hammers, prybar, a range of screw drivers (3 sizes each of phillips, slotted and robertson), 6", 10" and 12" adjustable wrenches, torque wrench, complete SAE and metric socket sets in 3/8" and 1/2" drive, random orbital sander, sawzall, 18V skill saw, compound miter saw, digital multimeter, soldering iron, hot glue gun, angle grinder, lathe, milling machine, silver soldering setup, etc. I keep everything but the large stationery tools (table saw, band saw, surface plane, etc.) and 110VAC tools on the boats, which means I have two of everything. I do have a Gerber multi-tool that I use mostly for rigging work. I selected it because it has a comfortable hand grip
