… in our 1986 Tartan 40, lots. A couple years ago, I started an Epi Gloss (on solid stock) & Rubbed Effect (on veneers) program on various things, it'll take me a while to complete this one, but in the past, I had always used Watco Danish Oil Clear on my teak and it always came out looking very nice. I would clean the teak with alcohol or acetone, then a light sand using papers or Scotchbrite, vacuum & wipe it down with thinner, then the Watco, I used Jen-Poly foam brushes, and generally couple coats. Cheers, John
