I would certainly follow the manufacturer's recommendations. My understanding is that the alloy in aluminum anodes is effective at protecting aluminum sail drives and other aluminum items under water because the composition of the sail drive alloy is galvanically less active than the aluminum anodes. Perhaps your aluminum thruster blades have a surface coating that protects them.
