Looks tough to pump.
Buried in the locker like that, tough to move the handle. Next time it's open, check that the hinges on the valves are up. Might just be a matter of rotating the valve flappers.
That pump looks different from mine - perhaps horizontal vs vertical models? Mine is located on a vertical bulkhead, pump runs fore/aft, and the handle is vertical. See if I can get some photos..
