Return to Index
Read Responses
Top or bottom inlet?
In Response To:
Mine are all mounted vertically
Manual Bilge Pump
Al, I have the same pump. It's worked
Similar Problem with Henderson MK V
I have three Henderson/Whale pumps aboard
The Henderson Mk V has two kinds of valves....
Bottom or horizontal inlets depending on the mounting space.
I have one for the overboard holding tank discharge, it needs rebuilding often.
Ditto - same pump!
Beats me. Here's my install.
Looks tough to pump.
Ah, there's an idea.
