Probably more critical stick to that guideline with my 7/8" shaft than it would be for your 1.5". I had a new shaft made a couple years ago. I pulled the shaft and shortened it last spring leaving just enough room for a donut zinc and 1/4" for the cutlass bearing. I didn't notice any shaft whip with the extra length but the prop face clearance past the rudder was a problem.
