Return to Index
Read Responses
Here is our 1 1/4" shaft on a Catalina 42
In Response To:
How far can a prop shaft overhang
Photo from 12 years ago. Shaft is stock so I would say it is typical of the 1000+ 42's made.
There is a formula used
We have a lot more than that?
If you have a lot more than that
You are right, upon reflection I don't have a lot more on my 1-1/2" propeller shaft
Two prop and shaft shops told me the same thing, Larry
If it worked well before...
It does work, but with vibrations that
Shaft whip can bend it permanently.
A "whip" is function a complicated series of harmonics
Prop overhang
Did you have vibration?
Yes and No.
Under what conditions?
It is not actually a vibration.
