Shaft whip can bend it permanently.
If it creates a problem the possible remedy might be you'll need a new shaft. If the bend is gradual in the middle sections of the shaft it can be straightened, but if it's near the start of the taper you'll be spending some bucks for a new one. Either way it'll require an extra haul-out and yard expenses. Been there.
