Return to Index
Read Responses
should read: Pin to anchor or pin to chain
In Response To:
Pin to anchor or pin to shackle?
Rock Slot.
Pin has to go to chain...
+1 on that pin to chain
The Crosby G-209A is even better
I think the G-209a are the same
Think you're right - Silver Pin at Hamilton
We used a SS shackle to attach our 3/8" HT chain to our 65# CQR
SG which SS shackle is stronger?
It's been over a decade, but many are, as you say, not stronger
A non marine store source
Stainless shackles
I have always used the pin to the chain. The
All anchors have an elongated hole
Always avoid always...
I meant well-designed anchors
Ah yes, :^O ;^)))))
If pin must be through shank
That's my set up but with a swivel.
That's a lot to do
You know, it sounds like it is a lot to do
Disappointed in you, Doug - I thought you had gone with a titanium shackle... (grin)
Hey Jon, afraid to have dinner cause you'll get soaked with gin?
