It's good that you left it
The fuse is to protect the wires and devices. If the maker specs 6 amp fuse then that means 10 amps might cause a melt-down inside the unit. BTW I think you should be OK with it sharing the circuit. Mine shares a circuit with the stereo radio (standard auto radio) and no issues.
