You can make an accumlator out
of an 6 inch section of schedual 40 PVC pipe, 2 end caps and a T tapped in one of the
caps. The air is just compressed and made into a shock absorber. It's nothing complicated. There is no real reason you need a bladder inside except it makes it eaiser to load with air.
