I was looking for information on what flares I need to renew...
Then I saw this:
Rule 25 - Sailing Vessels Underway and Vessels Under Oars
(e) A vessel proceeding under sail when also being propelled by machinery shall exhibit forward where it can best be seen a conical shape, apex downwards. A vessel of less than 12 meters in length is not required to exhibit this shape, but may do so.
So according to the rules... if you are under 12 meters, there is no requirement to show the inverted cone... and apparently that inverted cone rule does not apply in international waters...
http://www.navcen.uscg.gov/?pageName=navRulesContent#rule25
