Return to Index
Read Responses
Or bottom insulator is 10' above the deck
In Response To:
24" separation from backstay and hf radio antenna wire
Seems fine, at least wig the Hella lights.
Looking into LED Nav Lights for pulpit and pushpit
Do you have an SSB?
Ummm... the feed wire below the insulator radiates RF too
And receives
SG, how close is your light to insulated antenna wire?
The back stay is about a foot from the light
Thanks SG, the system is the same once it leaves the tuner I believe
The "feed wire" is part of the antenna...
Brain, are you saying you should
Steve high voltage non shielded conductor
Yes, That is what I am saying...
Do you use your deck level lights under sail?...
I switch from deck level to masthead
Good point Brian, but since I am moving the fixture I am going to spring for led.
Tri-Color
While motoring offshore, I have known people who have not had their steaming light and deck lights on
Rule 26
If you are motoring with just the tricolor,
Have been using Hella LEDs
Have you....
Thanks Greg I did consider the Monitor
