got to get all the specs. on the different ones and start doing some in depth investigation. I'm just starting to think about it. The last trip up the Baja with Chuck we were actually going backwards on the GPS. I want something that will punch through that stuff. I also want something reliable. Denny is pretty much done with engine trouble. When she starts bringing up changing out the engine you've got to know that maybe it's time I should start thinking in that direction. To her an engine is something that should be out of sight and out of mind. Our last season in Mexico was tough. It's seems people are pretty happy with the Bata and that's a good thing because we have a Bata dealer here in SD. I talked to him once at the boat show. If he can make some mounts that drop the engine down low enough like Brian and John both said then it sounds like that maybe the one to start looking at. It's still down the road a bit. I'm still in the middle of "re-fitting" the Jeep.
The new lift kit I had put on it did something to the front end. It never ends. We're looking forward to seeing you for the 4th. Come hungry. Oh, bring a couple of Uncle Sam hats if you can dig some up. I want to win the free drinks again.
