Return to Index
Read Responses
Wonder what Rob, just plain Rob has to say before Rigger Mortis sets in!
In Response To:
My rigger advises to use silicone sealant
Good source of silicon bronze metric screws? Saga of the rawwater pump...
Okay.
Yes and...
We replaced the brass/bronze screws with
Thanks.
The reason I am concerned about Tefgel...
Good one, Charlie. You're killing us here!!!
Gene.......
Pull the pump.
Didn't even "work on it in place..."
Is the pump still mounted in that backward manner.... with the face toward the engine?
Yes, it's still.....
Same issue on Volvo MD2030
I've been using the same impeller 3 years
I've used them for years also.
I used to do that
