Return to Index
Read Responses
I've been using the same impeller 3 years
In Response To:
Same issue on Volvo MD2030
It works. But maybe I should check it.
Good source of silicon bronze metric screws? Saga of the rawwater pump...
Okay.
Yes and...
We replaced the brass/bronze screws with
Thanks.
The reason I am concerned about Tefgel...
My rigger advises to use silicone sealant
Wonder what Rob, just plain Rob has to say before Rigger Mortis sets in!
Good one, Charlie. You're killing us here!!!
Gene.......
Pull the pump.
Didn't even "work on it in place..."
Is the pump still mounted in that backward manner.... with the face toward the engine?
Yes, it's still.....
I've used them for years also.
I used to do that
