I use......
a very low cost non-contact temp sensor. Got mine from Harbor Freight and started using it for the engine to check temp every so often and keep somewhat of a running log. If I see the temp rising, I will take action.
After I started using it, as it is NO-CONTACT, Jill even started using it when cooking! We like duel use items.
You can see ours at;
http://youtu.be/HIs_iJDLw6U
