IR Thermometer
In Response To: I use...... ()
GREAT with out cast iron fry pan - check the temp and set the heat. For years I used an aluminum fry pan, Teflon lined, with the thermostatic control. Picked up an iron pan at a tag sale for $3, cleaned and reconditioned it, and it is now our primary fry pan. Even the wife has become a convert. The IR thermometer makes it easy to use.
