Return to Index
Read Responses
Correction
In Response To:
The TV see's the network
I wrote Apple Airport Extreme in my last post, but meant Apple Airport Express
Smart TV question
Authentication method?
On our marina WiFi I called the service provider with a problem connecting
No such thing as "Google protocol"
I think Larry is right
It might as simple as a Fixed IP address or some other setting?
Mark - many variables
Thanks Larry. I will try that.
Correction
I like you neeed to enter the "password" at every marina
It is an authentication problem
Some WiFi networks block streaming content...
You can easily get around that
Dunno if my smart tv is that smart
use a gateway router or HDMI
The slower wi-fi networks may not connect a VPN
VPN overhead
