Return to Index
Read Responses
thanks for the tip
In Response To:
Go to the auto parts store and buy a pack of Bondo spreaders
OK--wood experts--how do I
Sorry what was the question?
YOu mean IN the grooves? Bend sandpaper to shape is one way...or....
thanks for the tip
I have started using foam sanding blocks..
I have many foam blocks of various hardness and size. Ran a refinishing shop for 25 years, and built boats for 10
DIY
I rest my case.
A cabinet scraper can save a lot of time.
Wouldn't you use a heat gun after removing the steps for refininshing? Then sand?
Yes, if he's removing an existing finish, varnish, Cetol, etc.
Certainly can, but the question was about removing finish from the grooves.
Remove the steps from that ladder and
yes
Think Trex
