Return to Index
Read Responses
I have started using foam sanding blocks..
In Response To:
OK--wood experts--how do I
Many diffierent shapessizes and grits, check your local hardware store or online.
Sorry what was the question?
YOu mean IN the grooves? Bend sandpaper to shape is one way...or....
Go to the auto parts store and buy a pack of Bondo spreaders
thanks for the tip
I have many foam blocks of various hardness and size. Ran a refinishing shop for 25 years, and built boats for 10
DIY
I rest my case.
A cabinet scraper can save a lot of time.
Wouldn't you use a heat gun after removing the steps for refininshing? Then sand?
Yes, if he's removing an existing finish, varnish, Cetol, etc.
Certainly can, but the question was about removing finish from the grooves.
Remove the steps from that ladder and
yes
Think Trex
