Return to Index
Read Responses
Yes, if he's removing an existing finish, varnish, Cetol, etc.
In Response To:
Wouldn't you use a heat gun after removing the steps for refininshing? Then sand?
OK--wood experts--how do I
Sorry what was the question?
YOu mean IN the grooves? Bend sandpaper to shape is one way...or....
Go to the auto parts store and buy a pack of Bondo spreaders
thanks for the tip
I have started using foam sanding blocks..
I have many foam blocks of various hardness and size. Ran a refinishing shop for 25 years, and built boats for 10
DIY
I rest my case.
A cabinet scraper can save a lot of time.
Certainly can, but the question was about removing finish from the grooves.
Remove the steps from that ladder and
yes
Think Trex
