A cabinet scraper can save a lot of time.
In Response To: OK--wood experts--how do I ()
You'll need to find or make the right shape for your grooves and work carefully. Scrapers remove a lot of material quickly but you can gouge the wood if you slip. It will reduce your time spent hand sanding.
