Return to Index
Read Responses
Makes sense for the hatch cover...
In Response To:
One more advantage...
...not so much for the instruments and the control panel.
What's your winter projects list?
Snorkeling, swatting bugs, drinking rum served in coconuts
You still in the yard???
New main hatch slides, bit of sewing on the dodger.
First, installing a mini split heat pump. Exciting advances in air exchange heat pumps.
A few lines need the ends rewhipped
Pulled the heat exchanger
Not all that much this year compared to last year
not as much as last year
Same as my summer list
The usual varnish jobs are always on the table. Then
Covers. So what works best... lift a dot, snaps or twist?
Snaps get my vote
Certainly they have the advantage of not being...
I agree snaps are best unless you are going canvas to canvas.
I run a candle over the snap every so often to keep it free
Though DDW's elegant solution is intriguing, we have snaps (similar to LarryDH's)
I hate the snaps and twists...
Here ya go...
That's actually
I guess that's a good point.....
Engine Rebuild
