Return to Index
Read Responses
What were you using before?
In Response To:
Well, the jury is back on my Pettit Hydrocoat ECO...
And where do you keep the boat?
Is the water clear or turbid?
Impressive!
Three seasons with Micron 66, seven seasons...
As good as Micron 66?
Micron 66 did a good job...
A friend also had his Micron 66 come off in sheets
Interesting!
If you look it up on Yachtpaint.com
Bad prep.
On a seperate note I'm pleased with Awlgrip M3131 Spar Varnish
