Micron 66 is the best I ever used but it was too soft and would rub off on the lines then stain the decks. It also is permanently deactivated if you take it into fresh or brackish water, so that means you can't take it up a river.
I'm using Micron Extra now and found it to be only slightly better than Pettit Hydrocoat (original with copper) in Western LIS.
