Troubleshoot with non-electrical gauges.
For temperature, try checking with an IR or contact digital thermometer. For oil pressure, remove the electrical sender and screw in a real mechanical pressure gauge. Find out whether you're chasing a real problem or an electrical gremlin. FWIW, with two wacky readings I'd suspect electrical - probably a ground.
