Look again -- what matters is the geometry between the blade and the pull attachment point, not the arc of the shaft. If it was a semicircle it still wouldn't matter vs. a straight or angled shaft -- what matters is the blade attachment angle relative to the pull point. Also weight must be distributed on the point to encourage setting.
