Re: Dinghy chaps/You aren't missing a thing. If / I've had / Also, the straps that go /I can say tha
I haven't ever experienced any slipping. I, once again, believe that the secret is having the chaps tight on the tube. Mine are secured with the draw string on the outside and short lines secured to eyes on the inside. Both to the bottom, front and transom. Having them fit tight is the overall answer.
Ured
