Return to Index
Read Responses
You do live in an historic area, kid!
In Response To:
50's and fireworks in Rockport Maine tonight.
We do, Westie. But we lose pieces of it all the time.
That guy's lawn in front of you ...
While 2015 is on track to be the warmest year recorded, it will turn on a dime around here, John.
Looks like it is time to put the camera down and pick up the paint brush
I was hoping nobody noticed,... Can you tell that railing is cut out of a pressure treated 4x4?
pressure treated 4x4 paint
I may have to do that way. PT amazingly rot resistant, but it checks like crazy if not protected.
Does the extrusion below that the PT Plate sits on drain?
No it is flat. The whole railing system sits on plastic spacer blocks to keep it dry.
You could glue it down...
