 () That looks really cool. Also limited controller range, however (they say up to 300 ft but "up to" are key words). You should be able to get nice shots of the boat and vicinity but if you go beyond ~100 feet you increase risk of fly-off. I lost a Hubsan mini drone like that. Unless the drone has GPS with "auto return to base" it's not wise to test the control limits.
Also, in any populated area I'd advise you to keep the "indoor" prop guards on. Those tiny prop blades could injure someone.
