Return to Index
Read Responses
Well....
In Response To:
Probably would have been more elegant, but this should work.
If you used 5 or more laminations you would have almost no springback.
A mating flange: I realized, no way a solid piece will make the bend,...
I think you could have done it if you steamed the piece
Well....
Strength? I don't solid is stronger?
You're an architect; think of hanging one end of a floor, with a 20" span.
The span is affected by fastners on "plate" that the deck provides;and where it's attached otherwise
The dynamic load of two JRTs, for example.
Re: A mating flange: I realized, no way a solid piece will make the bend,...
I hadn't, but that's a good idea.
