Ground?
In Response To: Yanmar 1GM alarm question ()
Then all the other terminals for corrosion and or a bad connection. It should be easy to check the sensor. It should have an open circuit when you check the continuity between the terminal and the block. It should only close when it senses high heat(which it sounds like you ruled out).
