Alternatives
In Response To: Hydronic heating system ()
I looked seriously at an Espar, and looked briefly into a hydronic system. In both cases I didn't like all the holes I'd need to drill in the cabin for pipes and vents, the large electrical draw they both demanded, and the relative complexity.
I ended up going with a Reflex diesel heater which couldn't be simpler and requires no electricity. For hot water we have an on-demand propane heater with the output temp set to about 100F so you don't need to run two lines and waste water mixing hot/cold. We've been very pleased with both.
It took a few iterations to get the right chimney for the Reflex. We've learned that "H" chimneys are best for yachts to avoid downdraft, and in cold temps an insulated above-deck pipe is recommended. I think the Dickinson stove has a fan assist for lighting that is a nice feature, but the Reflex is smaller and fit our available space better.
Just a couple alternatives which might or might not suit your requirements. Good luck with whatever you do.
Max
