Return to Index
Read Responses
Propane
In Response To:
Re: Alternatives
That and the CO issues, etc. If you use a lot of heat, propane is more expensive per btu...
Hydronic heating system
As usual, I'm no help but curious to hear the outcomes!!
I had an Espar air heater in my last boat
We've had Espar's forced air on two boats over about 29 years.
Alternatives
Re: Alternatives
Propane
Re: Propane
We had a sad case of an on-demand propane water heater in a head killing a woman sailer from CO
Propane fired on-demand heaters have improved a lot....
Re: is THAT why the stack is ~3" while the Cozy Cabin Heater only has a 1"?
The engineering and effectveness of a stack at sea isn't so trivial a concern
So far we have not had back draft problems with the double stack...
Exactly, the exhaust stack is a 1" tube inside the intake stack....
Well installed cabin heaters
You might call Ocean Options in RI
Re: Hydronic heating system
Belated thanks for the information.
Hagar, thanks for the rest of the story
