Additional thoughts
You could cold mold trim piece, then sand, and maybe varnish or oil it.
You might consider teak plywood; and.or 3/4" thick piece that is inserted into the hole that was originally drilled for the switch was clean enough. You might insert it into the "hole" to create a reveal.
If you get you can get thicker teak planks and plane them down to 1/4".(nl)
