Return to Index
Read Responses
Does the unit that you have need ventilation?
In Response To:
Absorption refrigeration??
Same process as a propane refrigerator
5-6 amps is a huge draw
Re: 5-6 amps is a huge draw / Yes, that's a huge draw. I burn
Craig's at a slip -- not a a mooring
Re: Same process as a propane refrigerator... I was fascinated by this... until
what about heat generated?
Yes, it would require some method of cooling...
electric, not propane
great minds or simple minds? Thinking alike
upon futher investigation this does not seem like a good option
Have you considered one of the portable compressor based units?
On my list to look at
