Return to Index
Read Responses
great minds or simple minds? Thinking alike
In Response To:
Does the unit that you have need ventilation?
Absorption refrigeration??
Same process as a propane refrigerator
5-6 amps is a huge draw
Re: 5-6 amps is a huge draw / Yes, that's a huge draw. I burn
Craig's at a slip -- not a a mooring
Re: Same process as a propane refrigerator... I was fascinated by this... until
what about heat generated?
Yes, it would require some method of cooling...
electric, not propane
upon futher investigation this does not seem like a good option
Have you considered one of the portable compressor based units?
On my list to look at
