It appears the thruster tunnel was added after initial build and Beneteau cut out a wedge section beneath the thruster tunnel to gain access and glass in the tunnel tube. Then they did a crap fiberglass repair job and failed to blend the wedge cutout section back in with enough overlapping layups. That was a really bad.
