Return to Index
Read Responses
Thanks, I have seen that stuff in use before - white grid like layer. Thanks for the tips. (nm)
In Response To:
plastic sources
Well, it's snowing here...
snow here for the next 3 days (link)
When you shrink wrap something yourself like that,
Kinda long story (link)
be very careful....this guy knew what he was doing and he set his marina ablaze
Can heat from the gun have a bad affect vinyl lettering or foam-cored hulls? (link)
OK let's see Craig. We have shrink wrapping the boat
Not a fan Steve (link)
He Sorely Does ...
If you are going to keep you boat where it needs covering (link)
Fairclough makes very nice covers but there is no ROI compared with blue poly tarps
laminated plastic sheet with scrim
That sounds great. Could you give an example of...
Clear tarp (link)
plastic sources
mast up storage?
Mast up -- slit the cover and tape with a strong tape (nm)
All true............except one thing you missed (link)
