Return to Index
Read Responses
At around 2200+ RPM (nm)
In Response To:
Hey PaulL, when you say you had overheating "under stress", at around what RPMs did this occur on your Volvo 2003?
DQOTD about installing temp/oil pressure gauges
Gauges and senders must match.
Gages and senders
I hav seen VDO guages/senders replace some Volvos (link)
Sded, have you ever had an overheating problems with your Volvo 2030?
I actually have a 2003t (predecessor) (link)
Possible soluiton to overheating
Volvo 2003
Mike, Sded...thanks for the bits of info. I'm always hesitant to ask for advice on this since
The solution on my Volvo 2003 was radiator flush
Larry, a few years ago, I had a local guy build me a panel using all VDO stuff
Thanks Jud (nm)
Look in your defender catalog...
Yes I saw them too, but need to work out the nuances
I added gauges to our Volvo
Just use the auto stuff. A volvo is . . .
