Return to Index
Read Responses
I'd use blue
In Response To:
Shaft coupling bolts question
I'd use blue
Use the blue stuff.
I'd use red...
No, No, No...
Metric bolt grades
OK, But are you sure those are metric...
To avoid any possible confusion on the original question,
Why would you change to a high tensile
The purpose of a bolt...
I agree 100% with your point about friction/force.
That's a good tip on the 304+316 combo on the nut and bolt.
Another good reason to mix stainless'
Nope, 5 hashes on Gr 8
According to...
I wonder if it used to be different?
As I recall...
Sure looks like I made that up out of clear blue sky (about the 5 hash marks). Weird.
Looks like we both have egg on our face!
SS Bolts
Dave, I suspect that you might be correct
One word. China
One word. China
Why not use proper hardware source...
Another good one is Fastenal. Branches in most cities.
McMaster Carr has stainless with fairly small box sizes
McMaster Carr is a great place,
The only reason I don't shop bolts
I wouldn't use SS -- it's not as ductal or strong
I use Super Lube Anti-Corrosion Gel on the same setup you describe
