Return to Index
Read Responses
You might try peanut butter...
In Response To:
In Hull Transducer
instead of the Vaseline. I've used it in the past with good results.
Oh, use smooth not chunky
In Hull Transducer
The first time I put the transducer on the inside was
my old Signet transducer ...
I find..
No hole mounting
I used a similar technique on Rosebud - worked great!
I mounted one with silicone in an Islander 30...
I use Plumber's Putty for a dry fit check..
Hawk-Eye
