Return to Index
Read Responses
I used a similar technique on Rosebud - worked great!
In Response To:
No hole mounting
In Hull Transducer
The first time I put the transducer on the inside was
my old Signet transducer ...
You might try peanut butter...
I find..
No hole mounting
I mounted one with silicone in an Islander 30...
I use Plumber's Putty for a dry fit check..
Hawk-Eye
